Wonder if you could give me some advice about the Iwata HP-CS airbrush. A friend of mine has a unused one for sale and is offering it to me for £50. As I am new to airbrushing I do not want to waste my money buying it hence my request for your advice please. Just some back ground into what it would be used for, I build 1/200 1/350 model ships. Will it be able to cover the hulls etc or is it just for fine work?
£50.00 sounds like a bargin, but make sure it is in good working order first, spares are easy enough to get in the UK, but expensive.
I find it a quality bit of kit, easiest a/b I’ve used, setup, use, & strip-down very easy, 5 years old & still using the original tube of needle lube.
The CS I have came with a 0.3 needle & head & will cope with some fine work, but I over-tightened the headset, knackered the needle & I replaced it with a 0.5 headset & needle (NOT interchangable) & this copes even better with Valejo & Tamiya acrylics.
I do mostly 1/35th Armour & 1/48th planes, but have done 1/76th, 1/87th & 1/60th armour with no problems… (other than talent not included [:$])
I would say it is excellent for most modelling, and if you find its capacity not satisfactory, you could always complete it with a new 0.5mm nozzle and needle. At that price its a bargain even with the cost of a new nozzle and needle.
