Is any one, building it or have any Reviews?
I saw it in my LHS the other day, with the exception of the decals its a striaght reissue of AMT’s BUFF kit.
If you can find a review of AMT’s B-52 on the net (shouldn’t be too hard) and the FSM issue from a few years back where Paul Boyer shows how to correct the kit’s lack of wing droop, you should have all you need to get a start on one.
I did a bit of poking around and found this build article on ARC. The author includes their email address so maybe you can contact them if the address is still valid.
http://www.aircraftresourcecenter.com/Gal5/4601-4700/gal4639_B-52_Gist/gal4639.htm
Thanks, I just picked it up from my H.S., but I did not know it was a AMT re-box. The thing was $80 for a pain in the 6 kit.
Somebody charged you 80 bucks for that kit?![:O] Sounds like highway robbery to me.[:(!]
I never saw it for that much when it was first put out by AMT. I might expect that kind of price tag if AMTech did some kind of fancy reissue with some resin bits on a limited run basis, but not for a near direct repop of it for the mainstream as Italeri is doing with it.
All the same, good luck to you on it.
