Hi wonder if anyone can elp me with italeri model freightliner. In the instructions it says holes have to be drilled in some of the parts, can you explain wh this has to be done and also what size oles they need to be .
Hanks
Graham
Hanks
Graham
I’m completely ignorant about the subject, but:
Welcome to the Forums!
Hopefully someone knows the answer.
Welcome aboard. As said above, i can’t help with your question. Try posting in the relevant section. You will be more likely to get an answer that way.
Don’t know,but welcome aboard.
Hi Graham! I can’t help out either but welcome to the Forums.
If you post this question on the “Autos” section of these Forums you will probably get more help than you need. The members there are very knowledgeable and ready to help.
Good Luck.
Jim [cptn]
Hello!
Welcome to the forums!
I have a 1:24 Freightliner from Italeri and I have completed another truck model that is based on the Freightliner frame, so chances are I could help you - I’d suggest you post scans of the instructions with the critical portions marked (say, in pencil) - and I’ll tel you what I think about it.
Hope it helps, have a nice day
Paweł
