Israeli Pilot
Hello vevrybody. I want to build a diorama based on the eduard mirage IIICJ. Does anybody know if there is some '70s israeli pilot or ground crew figures in commerce and where to find them?
Thank you
Giulio
The only pilot ground crew set I can think of is Hasegawa’s Pilot and Ground Crew Set in 1/48 or 1/72nd scale. Although the figures represent US pilots, the ground crew would probably be similar to Israeli, But the pilots may need modifications since the Mirage was a French plane so their gear differs. The pilots would probably be OK as is for A-4, F-4, F-16 or F-15 Israeli pilots. Hasegawa’s pilot set is quite common and should be easy to find.
Try this link it has a photo of a mirage pilot and some ground crew for reference.
http://idfmodelling.free.fr/mirage.html
