I have heard of people using things like dirt from the garden, tufts of grass, and twigs in dioramas. I often wonder about the risk of having substances that will decay, or might have bugs in them, or something of that nature.
If you use organics, do you do anything to sterilize them? Are you worried about decomposition? Do you think there is anything to watch out for?
I always followed Shep Paine’s advice and sterlized whatever I dug up out of the ground or scavenged from outside. With soil, a quick trip into the oven ensured that whatever was in the soil was made safe for use in a diorama. Any more, however, I just don’t bother with it at all because the market is filled with products to create better scenes which are typically more in scale and more convenient to use.
I use well sifted dirt from my yard in the few vignettes & dioramas that I have made. No problems from those. I also have used twigs gathered from various places, and no problems there either. One other organic source that I have used, and is perfectly safe, is food spices such as oregano to replicate foliage on the ground like dead leaves. Yes, there are plenty of things out there that you can buy to fill these roles. But if you’re on a tight budget, a little creativity can make you money go further.
I hit everything with a couple of good coats of matte varnish when done. I think that’s enough to keep critters from munching on it. So far (cross your fingers) no problems.
Here’s a little decoration for a vignette, made with a piece of root from an arborvitae and some old tea leaves:
The shrub had died, so I had to dig it out. I saved bits of the finer part of the root network. I soaked them in a bucket of water for a little while, till the rest of the clumps of dirt dissolved and fell off. Then I set the roots to dry in the sun. I just cut little bits off as needed. For the foliage, I used fine tea leaves collected after brewing up a cup. I have a small plastic jar full of them. I just brush a little white glue onto the roots and sprinkle the tea leaves over them.
I’ve never tried using sifted dirt in my builds, preferring to stick to more refined and controllable pigments. However, I’m not averse to using some twigs or sticks for dioramas…depending on the project and application, they can be better choices than more expensive products.
One of my favorite YouTube modelers, Hamilkar Barkas, is a big proponent of organic/backyard resources for dioramas…he uses dirt, twigs, and rocks to great effect in his builds.
Thanks, Jack! That’s from Ulrich Puchala, from his old 54mm catalog of Seven Years’ War figures. He moved on to sculpt larger figures, but his 54mm figures are still available from Müritz Miniatures in Germany, http://www.mueritz-miniaturen.de/, who paid Ulrich for the rights to produce the 54mm series. You might also get them through Chuck Robinson’s Red Lancers, https://redlancers.com/, located here in PA.
The SYW series is based on illustrations from Adolph Menzel and Richard Knötel. Though I paint mine in a gloss finish, because I like to evoke the look of a toy soldier, I like a well-detailed casting. Puchala’s figures are excellent, from this series to his Napoleonics to his WWII Luftwaffe ground crew figures.
I use sifted/non-sifted dirt, dirt that has been pulverized by heavy equipment, twigs, pebbles,seeds, anything I can find and imagine to make a scene. I have used grass seeds to replicate fish and dirt that has been sprayed with a gloss coat looks amazingly like mud. [:^)]
For those of you using real soil, do you bother sterilizing it, and how? I haven’t used real soil, but I had an idea that if I did, I’d stick it in a glass dish and microwave it, to kill anything living.
And while we’re talking about natural products, winter is a great time to collect fine gravel or stone dust. I get mine from the street out in front of my house, especially from piles of plowed snow. I use an old garden trowel, or even an old tablespoon, to scrape the “dirty” layer into a plastic container. When the snow melts, I pour off the water (and use that to water my plants), and then I pour the remaining slurry in an old baking dish, and stick it in the oven on the lowest setting. Once the water is evaporated, I sift the material by size, and store it in plastic jars for use in dioramas.
On bases I use it as texture over a base of spackle. I brush on Future then sprinkle on the sifted dirt. Repeat as needed to get the look that I want. I’m pretty sure the Future will deal with anything in there unwanted. Adding any paint on top to color it just adds to the kill.
I gave up on dirt for terrain so i make my own out of Durhams Water Putty sprinkled with either fine play sand or crushed kitty litter. I then use craft acrylics to color the ground. After that I use diluted white glue as a bonding agent then dried flowers and foliage from HL.
Here is an abandoned tank dio using the above method.
