As Rob says, the biggest outward difference is the 8-shot smoke launchers. The MCD is not always installed, so it isn’t really an identifier for USMC tanks.
8-shot, double-stacked, USMC type smoke grenade launchers.
Other features of modern US Army and USMC M1A1 HCs and M1A1 AIM tanks.
BFT antenna (w/ GPS antenna on it) attached to gunner’s doghouse.
You will not usually see both the EPLRS antenna and a BFT antenna installed on the same tank. It is usually one or the other. The EPLRS antenna mounting post will still be present when the BFT antenna is used, just with a blanking plate on it as opposed to an antenna base.
APU Power Junction box. New electrical conduit is the angle-iron piece running along the left side of the blow-out panel.
Power connection box next to the man-hole cover. There are two screw caps to connect to located on the front of the connector, toward the front of the tank.
PLGR antenna is mounted somewhere on the turret roof. It is usually in front of the crosswind sensor. I have also seen it to the front right of the TC’s cupola as well. The location for it varies.
Tank/Infantry Phone and rear Slave Cable Receptacle on right rear of hull on latest AIM tanks. (Added in '07. Prior to this, they had just the T/I box on the right rear.)
Deep fording kit exhaust flange on HCs and AIMs.
The box in front of the loader’s hatch is an MCD (Missile Countermeasure Device). It is used to defeat optically and laser guided anti-tank missiles.
Some USMC M1A1HCs are using the old sprocket retaining rings as well. They were found to be an easy fix to counter the track losing tension during operations. The USMC started putting the rings back on M1A1HCs in the early-mid nineties that were stationed stateside on the West Coast (1st Tank Bn) and they were seen on tanks on deployment with the MEUs until 2006. No rings are/were on the sprockets of East Coast (2nd Tank BN) tanks though. Most USMC tanks that came off of the Maritime Preposition Ships (MPS) in Kuwait for OIF I /II did not have the sprocket retaining rings, other than at least three known tanks that came off the MPS ships with them. The USMC tanks that have been seen in Iraq with retaining rings are from stateside (1st Tank Bn). They are part of the different ocean-going Marine Expeditionary Units (MEU) that have gone to Iraq and participated in the festivities over the past few years. So, specific USMC tanks could be seen with the rings applied.
The below pic is a USMC M1A1HC in ops in Kuwait with the rings on it.
USMC folding BRE used in OIF.
Hope that helps,
