What’s the best paint to use on the interior of car models? Gloss, flat, semi-gloss, enamel or acrylic? Any help would be appreciated. Thanks.
Yes!
Well, that’s the simple answer. All of the paints mentioned will work where appropriate. Some leather upholstery looks good with a stain finish, some vinyl looks good with a semi-gloss, carpet looks best with a flat, some dash detail is best with high gloss,…
A good mix of finishes really brings out the detail for an interior. As far as acrylic or enamel, look around this forum for a ton of opinions about the virtues of each paint.
Whatever you do, practice and find what works best with you. Have fun!
I find that semi-gloss works well for me, I can rub it here and there to gloss it a bit to make it look more realistic. Two coats (minimum) are recommended. Often primer works well for a grey interior, too.
