Interior color bleed through on a white car
I am attempting to paint a Revell Camero white. It is supposed to have a black interior, so I used a light grey primer under the hood and on the inner roof. Now I can see definite darkening of the primed areas through the outer white. What is the most effective way to seal/prime the inner areas so the black doesn’t show through? as I am primarily an aircraft guy, there are a few things I need to learn about these ground based things!
I think you will need to prime the exterior with a light grey to eliminate the bleed through. I’m not a car modeler, but those that know have told me that it should be followed up with flat white primer to provide color density, then finished with a gloss white. HTH
When you have color bleed through whether it be from painting a dark color on the inside like you did, or it the body was molded in a color that is bleeding through, the solution is silver paint.
I can’t explain why it works, but if you use silver spray paint instead of primer it kills the bleed through. Then paint whatever color you want over top of that.
Thanks for the idea! I wouldn’t have guessed silver! The kit comes in white and even a thin light grey is visible! I’ll try to remove the primer and try some silver. Any suggestions on what type of silver to use?
You don’t have to remove the primer. Just spray the silver over it. I use Tamiya spray cans, the TS series. I forgot the number. TS-13 maybe?
I’m going to have to try the silver paint. I usually use Tamiya white primer in a can for white, yellow and red. Pretty much anything that is a light tone or I want the top coat to be more vivid.
That reminds me to check if Hobby Lobby has it back in stock.
These guys seem to have you covered well in your area of concern but just wanted to say that it’s good to see you back @Lurch6531
@68GT
It doesn’t need to be Tamiya. That is just what I use. Any basic metallic silver paint will work.
