Intercoolers
i’ve found intercoolers as aftermarket parts, but none of them are the size i need. what would be the best way to make a few from scratch. i’ve seen radiators made from evergreen styrene before but i’m not sure what style styrene to get. anybody have any suggestions?
Evergreen (and probably plastruct) makes a sheet that is meant to be a small scale metal siding. It is grooved, with the grooves about 1mm apart. Evergreen’s item number is 4525.
A google image search will get you quite a few pictures of intercoolers, so you can model the style you like best.
I found an excellent tutorial here: http://www.briansmodelcars.com/tutorials/tutorial/2 This is exactly how I built mine, and it turned out great.
Thanks alot for the link. i think the only way you could have been more help, would have been if you offere to build one for me. don’t worry though i can handle it
