Idea?
Hi guys,
well its my 2nd time to post and im a new modeller, anyway i just wanna ask for a little help, im doing some figures actually and its almost done, but the problem is how can i make the SLINGS for thier rifles? im doing 1/35 modern military troops, can someone give me an idea, thanks so much…
[:D]
Jovs
First of all…welcome to the forums. I see the dark side has claimed another victim…er…convert.
For slings, belts, straps etc., old toothpaste tubes cut to the right size, aluminum foil, lead foil will all work well.
i havent tried it my self but most people use lead foil. I have used regular foil anf toothfloss for so-so results.
paper… its everywhere!!! and its as good as all the other things…if u need something thicker: notecards… hope this helps!! -DJ
Lead foil has the advantage that you can bend it to the shape you want and it stays put, no fiddling around trying to get the strap to stay in place. I also use .020 solder, available by the roll at electronic stores, rolled underneath a X-acto handle until it is flat.
I’ve used lead foil on several different applications and have been more than satisfied with the results.[:D]
thanks guys for the idea…
jovan
O, O, O I got one. I like to use the old brown paper bags that you dont see any more. the brown bags are a good color and their alittle thicker than regular paper. And… you can even cut it with a pair of sissors to the right length and CA glue both ends to the gun or whatever. Hope that helps.
My main material is lead foil but I also use Tamiya or 3M masking tape painted to the appropriate colour. [^]
here’s one coffee air tight lid it’s foil bends well and you can shape it . thats what i’ve been using.
get some foil from wine bottles, they work great.
Tissue paper. Use water to mold and after paint.
