I am having trouble applying the Future floor polish by airbrush. I have just started using it for the first time. Dipping canopies and other clear parts works great. When I try to spray it is a problem. Am I supposed to thin it? I am at about 10 psi on the gun. Light and easy spray pattern with 2 or three coats. Model paint is dry and clean. Poor results. It cleans off with ammonia and water so I haven’t screwed anything permanently. Don’t you wish you could do that to some paint jobs?
I do thin Future before spraying. I thin it with wind screen wiper fluid (winter pre-mix, that has alcohol in it) I use a 75% 25% Future/wipers fluid mix.
I have also tried bruspainting, it works ok on small models but not on big models.
I don’t know what to say about the surface. One was a car the other an airplane. The car was painted with Testors flat blue and the plane was Model Master Aluminum. Both were a day or two dry.
