I did a bad thing!
I sprayed a flat grey on the bottom of a B-25. I then used Ambroid’s EZ Mask to save the grey while I sprayed an OD on the top.
Anyways I can not get the EZ Mask to come off easy and it is taking the grey coat off with it. Does anyone know how I can get the EZ Mask off easily? The OD is enamel btw.
Thanks, Kilroy
Try wetting it with water. Soak a Qtip, apply to the masked areas, give it a couple of minutes to soften and remove with a blunted toothpick. It may require a few “coats” of water to remove all of it.
Thanks, I will try that.
I’m not having very good luck. Is there any solvent I can use to wipe away all of it without distorting the plastic?
I used some OOPS! all purpose rmover and it is just taking the enamel paint off perfectly. It is not doing anything to the EZ Mask or acrylic paint.
Wow, how long has the EZ Mask been in place?
Try emailing the manufacturer info at graphicvisioninc dot com.
Just replace the “at” and “dot” with @ & . !
