Does anyone use Humbrol Matt Varnish, #49, as their ‘flat-coat’ on a kit? What ratio of thinner to varnish do you use, if at all? Good results?
Thanks-
Glenn
Thanks-
Glenn
I have used it ALOT. I mix mine with Lacq. Thinner about 50/50 and spray around 20 psi. Works great.
Thanks for the input! Just what I was looking for. Will give it a try!
Glenn[:D]
I also use Humbrol matt but just thinned with mineral turpentine (can’t give exact dilution just until it happens to spray well) and at less pressure 10-12 psi
