My paint guide calls for mm fs36176 dark gray for the floor and half the inside colors
I only have access to Tamiya paint .
xf 53 neutral gray
xf54 sea dark gray
xf 56 metallic gray
http://www.tamiyausa.com/articles/ln/72/XF-chart-23ml.pdf
thnaks
xf 53 neutral gray
xf54 sea dark gray
xf 56 metallic gray
thnaks
Which UH-1B kit are you building and what markings are they? I am pretty sure the standard US color on Huey interiors is Gull Gray. At least until the late 80s when black came into usage in cockpits due to NVG flying.
That’s what the manual calls for . My problem I only have Tamiya acrylic paints local . No model master . I have Tamiya . If I order model master . Can I still use Tamiya acrylic For rest of the build Thanks Rick G
I understand that, but many times the instruction manuals in kits are incorrect. What markings and time frame are those with the kit? US Army Vietnam? Tamiya has a light gray color that would work, but it is not an exact match for the Gull Gray used on modern US aicraft interiors.Tamiya’s Olive Drab is a bit dark for the OD used on Hueys, but you could lighten it up with Buff to get a more accurate shade.
Would it be better to order model master enamels ? Thank you Rick G
I think , me and the wife will go on a trip to hobby lobby this weekend . Then pick up model master enamels . Then be done . Thank you Rick G
Yes, Model Master makes both of the proper shades needed for a US Army Huey during most of their service lifetime- Olive Drab FS# 34087 for the exterior, and Dark Gull Gray FS# 36231for the interior.
Thanks Rick G
my UH-1N in air rescue was flat black. det 6 40th ar\rs holoman afb
What time frame was that when you served on UH-1Ns? Just for reference. Was the entire cabin interior in flat black?
yep all black, except the rescue gear and hoist equipment. and 1986 till we were shut down
I presume you guys did a bit of NVG work? I was riding around occasionally as cargo in Army H models at that time. Those were still in all gray inside.
I have found that the color of Mr. Surfacer 1000 or 1200 is just about perfect for the interior color of a pre-NVG Huey. At least to me and I have built about 6 of em.
Ray
Yeah, that stuff is pretty close to Interior/Dark Gull Gray.
I wished ther was more options here . There isn’t any . I’m just goingstart priming . Then apply the best color I can . The. Weather wash it. . Hope for the best . Will send pictures Rick G
For the gray insides of Hueys, I use a cheap, Wal-Mart brand primer gray in a spray can. It looks right on to me.
light gull gray is correct for Vietnam era Huey’s. Testors has it in both brush and spray.
yep, nvg stuff every month dark of the moon
I bet that made for some serious pucker factor on occasion…
