hello has all .
this is my very first post which come from france on fine scale modeler , what I realize now .
what do you think about ?
phil .
hello has all .
phil .
I like the setting so far. This should be good!
Looking good so far. Is the wall home-made or a kit? If a kit, who makes it?
Hello Phil!
Your dio is looking good so far, I’m glad you decided to post! Good luck with your build and have a nice day
Paweł
hello .
thank’s , yes , heavy arty , it’s home-made , look this :
wooden stalks of 8 mm x 8 mm ,a plate of plexiglas or the glass , the adhesive tape , some plaster , small piece of wood or kadapak ( cardboard plucks ) for window or door .
with a putty knife , you spread in the frame having to mix the plaster with the water so that is thick and to let dry .
I engrave the covered in plaster with a point has to trace to bound the place or I wish to reveal brick and with the small scraper , I remove a thickness .
phil .
thank , pawel , I had to begin has to answer at the beginning of the evening but has 8:50 pm , american sniper passed has the tv , thus I have to look . r.i.p to chris , the legend . phil .
Nice technique, Phil - might have to try that sometime!
Still not getting the first set of pictures.
hello Ikar01 .
I put back them only for you .
and now with other photos :
and , I realize the hat of with plastic card of 1.5 mm of thinckness on 5 thnickness then sanding and sprue a ball of rotation of car has the néoprène , the ridgepole of the round door with plastic card and slates in 0.5 mm .
I share with you because it’s pawel who has on me to decide has to make it .
I have it to him to speak , seen that I asked him some questions on his DUSTER , and he told me : division .
phil .
Hello Phil!
Really cool stuff here, it would be a pity if you didn’t share with us! I’m glad I talked you over.
Other thing - I happen to know Phil would like to take a look at the TM for the Duster - maybe somebody of you know if/where it can be downloaded from the 'net?
Phil - good luck with your build and have a nice day
Paweł
Thanks for that.
You’ve done a heck of a job so far, better than I could do. Keep posting.
hello .
some small advance especially at the level paint then sticking of the walls on the base , the installation of filler of spackling on the ground with fingerprint of M48 tracks and a little greenery not painted at the moment made with hair of brush for the big and small , plumber’s tow .
I hope that everything is understandable in the translation .
phil .
has your comments , gentelmen .
Hello Phil!
Lookin’ very good - keep ut the good work! Thanks for sharing and have a nice day
Paweł
aloha every body .
after drying of the filler , the painting of the ground , the installation of the banister of the small staircase and its paint , the stincking of the flocking of toy train and engraving of hats of walls
on this photo , has right , the raw plaster , then the lines of pencil or I am going to engrave , the places of the bottom which were remove and the last one with the round top .
phil .
That’s some excellent scratch building! It looks like the set for “Full Metal Jacket”. What other items are going to be in this scene? Figures, Armor or both??
hello griffin25 .
yes , it’s a good scene of full metal jacket and I like this building always .There will be for vehicle , a M48 dragon ,a M37 RODEN , a M50 ACADEMY , a mule DRAGON , with HOBBY FAN and CALLSIGN figures .
phil .
Such a wonderful job on scratch building this diorama setting. Can’t wait too see it done. Outstanding job Sir!!
thank you , hunter ,I have still moved forward , thus I going to put some photos tomorrow , this evening it’s restaurant with my wife for our 13 years of common life , no model this evening , guy’s .
hi hi hi .
phil .
Happy anniversary, Phil! Best wishes to you and your wife for many more years together in health and prosperity! Really enjoying your work - thanks for sharing it.
hello .
thank’s , KnightTemplar5150 .
as promise , the continuation of work , I engrave the hats of the wall , like this :
and now :
this small roof of pagoda is made with the balsa wood , cardboard visiting card , and we call these yoghurts , Swiss young , I cut the top then the bottom and later I open and I put has flat , by cutting a width of 0.8 mm of a way has well to reproduce tiles and stack these bands to the top of the roof .
here is or I am there has the current hour .
I worked a little on the vehicles , M48 and M37 are from the box . for the M50 , I’m going to try to make a little scratch for the inside to make illusion because men make the load of munitions has to leave M37 .
phil .
