Hs 129 B3
Hs 129B-3
be to standardize on the larger 37mm gun, itself adapted from an anti-tank gun that had recently been abandoned by the army. For some reason the Luftwaffe decided to skip over this gun (although it served perfectly well on the Ju 87), and install a 75mm gun from the Panzer IV. A huge hydraulic system was used to damp the recoil of the gun, and an auto-loader system with twelve rounds was fitted in the large empty space behind the cockpit. The resulting system was able to knock out any tank in the world, but the weight slowed the already poor performance of the plane to barely flyable in this new Hs 129B-3 version.
B-3’s only started arriving in June 1944, and only 25 were delivered by the time the lines were shut down in September. A small number were also converted from older B-2 models. In the field they proved deadly weapons, but with only 25 of them they had no effect on the war effort.
The Kit: This is one of the nicest Hasegawa kits I have built. Construction is very simple with only minor filling and sanding. I only used liquid paper to fill seem lines and a polishing stick for filing. As you can see from the photos of the completed kit before painting, there is hardly any filling.
The cockpit is simplified but looks nice when painted and weathered. I like hand painting the instrument panel instead of using the decals, once the gauges are painted I apply gloss coat (Pascoes Long Life) to the faces to make them appear as if they are covered with glass. The entire interior is RLM 66 dark grey and highlighted using oils mixed to light grey. With the oil paints dry brushed and not completely dry I do a wash using Citadel Inks. These inks can be diluted with water and mixed with acrylics to get different tones. I like using this technique on the panel lines as well. Once the cockpit was painted and detailed I glued it in place and mated the fuselage halves together. With steady hands and CA glue a perfect fit was made and this reduced the amount of sanding and filling that I would need to do. The wings were glued together in the same fashion and the leading edges were polished. I added the flaps and built the engine nacelles but did not glue the engines in place until the painting process was done. The nose was glued on as well as the resin 75 mm cannon pod. This is a nice addition to the kit and comes with a a brass turned barrel and white metal tip, a very nicely detailed piece of work. I continued to build the remaining parts until all the main steps were finished. All that remained now was painting the aircraft, landing gears, gear doors, wheels, props, engines and exhaust and gluing everything together.
Painting the Kit: I used Gunze Acrylics for the splinter camouflage which cals for RLM 70/71/76. I started by preshading all panel lines and painting the masked canopy with RLM 66. Once the preshading was down, I painted the undersurface with RLM 76 Light Blue and allowed it to dry. Being careful not to pick the kit up too much I painted the RLM 70 Green over the upper surface being careful not to over spray the RLM 76, this was easy since the fuselage is angled. I did not need to mask this since I wanted a soft edge appearance on the lower fuselage. Scale Effect was next. I lightened the RLM 70 with a small amount of RLM 76 and used this mix to fade the panels and raised areas of RLM 70. I allowed the RLM 70 to dry for around 8 hours before I started the masking of the hard edge splinter camouflage pattern. Once the pattern was masked, I applied the RLM 71 Black Green in the same method as the RLM 70. With the kit now painted, I left it to dry and painted the remaining parts. Wing tips, nose, fuselage band RLM 04. Landing gear, insides of wheel wells, RLM 02. Engine plugs were painted and detailed and glued in to the nacelles. I painted the props and spinners RLM 71 and inserted them into the engine plugs. Wheels were painted flat black, and then dry brushed with light grey. The rims were glossed with Pascoes Long Life. The final construction was done and the entire kit was glossed using Johnson’s Shine Magic and allowed to dry for 2 hours. (this product is no longer sold in Australia, but I have a bottle which has lasted me nearly 4 years now.)
Decals: The decals are the kit decals which with the help of a very glossy surface and Micro Set and Micro Sol turned out better then I expected. I seldom use the kit decals out of the Hasegawa kits because they tend to be thick with excess sive carrier film and tend to silver. I was able to overcome all of these qualities this time. Once the decals were on I left them to dry over night and then I sealed them in with another coat of Shine Magic. I am not sure if it was necessary but I did not want to risk the silvering. Weathering was kept to a minimum, I only used a bit of silver pencil along the port side wing walk area and around the nacelles and prop blades. And airbrushed exhaust streaks on the wings. And accentuated the panel lines with a thinned Citadel Brown and Black ink mix. My last step in the finishing was applying the matte coat which was a combination of Shine Magic mixed with Tamiya Flat Base in a 7:1 ratio. The flat Base is very concentrated and should be carefully used or you will end up with a white powdery finish with white speckles every where.
Final Details: The final details included pealing off the Tamiya masking tape off the canopy, adding the pitot tube, gluing on the 75 mm gun, and adding the wire aerial made from invisible thread with insulators made from Krystal Clear, painted white and painting the navigation lights with Tamiya Clear Red and Clear Blue.
Slick ! Especially the way you handled the exhaust stains…perfect.
Great stuff there! I’ve always liked th 129 and you’ve done her proud!
Nice work! The paint chipping worked out well. [tup]
Great job looks awesome. Makes me wanna start mine
Jason
Excellent[tup] The painting, camoflage, and weathering are well done. Always nice to see the less popular aircraft.
Thanks for sharing.
ME TOO!
You are sharing some excellent builds here, this one is no exception. Are they recently completed works?
These are previous builds that I wanted to share since I have only recently returned to the hobby after taking a year off. Most of them were built in 2006-2007
Beautiful! The finishing is really great!
