How to strip Tamiya TS paint
I want to strip the TS paint and re-paint with different color. How can I do it? Thanks,
James
Haven’t used them yet but I believe these are lacquer-based spray paints. Try either oven cleaner or brake fluid to strip the paint off. They won’t affect the plastic though I’ve read of a few modelers reporting some “hazing” of clear parts, but nothing a rub of polishing or rubbing compound couldn’t fix. I think some also use Castrol Super Clean, but I’m not sure what its effects are on paint and plastic. Hope this helps.
Cheers,
onyan
That’s what I use, and it works fine on enamels and acrylics. Haven’t tried it on laquers though.
Isopropyl alcohol works .
It doesnt damage the plastic and is the same as the Tamiya brand acrylic paint thinners.
This stuff also works on Citadel Miniatures spray cans and will strip Vallejo acrylics.
Be prepared for a lot of rubbing.
It will also shift cured paint (acrylic) so if you want to strip an old kit for a fresh paint job its your best shot.
And its relatively cheap at €8 for a litre in any pharmacy.
