If you’re a beginner and wondering how to cleanly remove scale model parts from plastic sprue (sometimes called a parts tree), FineScale Modeler has you covered. Click here to find out the tools and techniques you’ll need to remove model parts from sprue without breaking or ruining them.
Everyone knows you use a chainsaw right? Twisting parts off was the way many of us started until an adult watching said,“Why don’t you use nail Clippers?”(The pliar type.) AHA. ! Fast forward Sixty five years. Ya got more sprue /part separaters than My late wife had shoes. It’s all good though. Because there are as many ways to do this as there are kits out there. Kalmbach covers most!!!
I never thought to use a razor saw to remove large parts with large attachment points and have actually been struggling with cleanup on those sorts of parts lately.
Always fun, not to mention humbling, to read beginner info and learn something. I have a bad memory and general lack of creativity, so I for one appreciate stuff like this. Thanks.
A jeweler’s saw is also a great way to remove clear parts and parts with large attachment points from the sprue. Finer teeth than a razor saw so it doesn’t hop around as much when starting, yet it works quicker. I use a #2/0 spiral blade for mine, and they last forever cutting through styrene, polycarbonate, and all kinds of resin/3D print casting blocks.
Those Spiral blades you mention. I first ran across them when doing very fine Wood scenics for a hobby try at something different. They are beautiful blades for just about anything!
Thanks for reading the how-to and leaving comments on this. It’s always nice to hear from you guys. Razor saws are useful in a lot of instances, and we make specific mention of them in this story and in our video about removing parts from sprue because people don’t often think about them in that context. And while everyone has their preferred method, we try to cover the magazine’s collected wisdom learned over the past 40 years and distill it for easy consumption. And we’re always looking for new ideas and techniques to share.
Have a good one!
PS. Greg, unimaginative or uncreative are not words I would associate with you.
Been using a bit of sticky putty on a toothpick now to prevent those tiny parts from going into orbit. ‘Figured’ that out after loosing one last fuel can lid!
While I ordinarily use nippers, when I want a really close cut, I use a knife blade. To prevent problems I use a #20 blade (big knife). The 45 degree blade does not bend or break like an 11 does.
Listen, Those saws are available in any Hand Woodworking dept of hobby stores. I think even H.L.Has some. If not, if you hear or read of a Juried Woodcarvers show near by. Go! There you will be exposed to a plethora of tools,e specially saws that will let you cut as clean as a laser!
I have blades that are as small as a thin thread, Round (so you can cut in any direction) and Regular. The problem? I am very careful with them, Cause I don’t remember where I got them! Also you can pick up a copy Of WoodCarvers magazine. If you see one grab it! The ads in the book will guide you to some fascinating stuff.
Another option is to use a clear, resealable bag large enough to fit the sprue in. You can put the parts tree into the bag and remove the part from the tree in there. If the part goes flying, the bag contains it. And those bags can get pretty large, so plenty of room for even a big sprue and your hand with snips. You can use the same technique for PE parts, too.
I’ve got an old Xuron cutter, but it’s a bit worn by now. I use a razor saw for a lot of sprue and casting block removal, too:
As others have noted, you can get fine cuts with saws like this. So depending on the size and location of the sprue gates, I’ll use the cutter, this saw, or a knife blade, too.
I think that’s the one I have too, Brad. I like mine too. Somebody here recommended it for resin casting block removal some time ago, wonder if it was you? If so, great tip and thanks!!! [Y]
Never would have thought to look at the woodworking dept at HobbyLobby or similar. Thanks for the idea, Doc, and all the other tips in your post above.
I’m away from home and the bench, but have plenty of spare time for window shopping and exploring. [:)]
I got one too! Don’t forget, you can by replacement blades from Micro-Mark! I have extras from them and I have fine, extra fine and regular. Best darned tool I ever invested in! I still use sprue cutters too, But, I modify them before I ever use them! Most sprue cutters are NOT flat on either side.There is a slight offset to the blades even on the flat? side.
I grind them(Don’t let it get hot!) to an absolutely flat face on one side and then take the tips on the deep side and grind them as thin as sensible to allow getting in small places where you have small parts. You can see them on my bench (If I had a pichure) and they don’t look any different until you pick them up and look closer.
