how to paint_ _ _ _ _ ???
hi any one can give me a hand in how to paint the Italian Savoia-Marchetti sm79 three schemed camoflage
Hi…post a profile…there are several schemes in three color camo…:wink:
thought i did pic was visible while writing i’ll re try. thanks
done :smiley:
I see two ways to do that. If you have an airbrush and can do those snaky lines, then you would paint the green, paint the brown, and then paint the snakes. Just draw the patterns on and label them G and B, and spray away.
A long time ago, when Scale Modeler was still young, there was an article on painting a Japanese fighter with the green patches over a natural metal aircraft, with the natural metal showing through around the patches. What he did was to paint the aircraft in the green color of the patches, then cut out masks for each of the irregular green patches, and carefully place them on the model. There were a lot of the little green “crooked dots”. After all the patches were applied, he burnished down the edges of each one last time, and then shot his Metal paint.
When he peeled it all off, he had what looked like a natural metal aircraft with field sprayed green blotches all over it.
someone else may have better ideas than these two,but, I can say that the method with the bits of tape actually worked for me once.
Rex
The only thing I can come up with aside from free handing it is painting the whole thing yellow and then using blue tac to mask the yellow stripe and individually paint the green/brown. Looks like a lot of work no matter what road you take.
a friend of mine has tried GLOSSY ACCENTS.you can find it at a craft store. i think its a clear acrylic medium in a container with a narrow nozzle. base coat the yellow add this and let dry, paint the green, mask and paint the brown. i have not tried this yet but have a TYPE XXVII waiting to try it on.
Aren’t there several decal sheets of various Italian camouflage schemes?
Hi…you need this book…:wink:
dfiles.eu/…/nnahta6nl
Gloster ,
Actually I get a kick out of painting camo like that. Personally I would start with an overall sand yellow, paint the brown or red splotches next, then fill in with the last color, and voilà or in this case e voilà!, easy as pie.
i defenitly agree with you mate
only one Don Stauffer
