Hi,
can sombody please tell me how can i make rubble for a diorama [:)]
Hi,
Pieces of Balsa wood strip from the hobby shop for broken beams (A 6" x 6" beam would be 0.17" x 0.17" in 1/35 scale), sticks for trees/branches, small gravel from the driveway for stone.
hope these ideas help
Kitty litter (preferably unused), scraps of gyprock…just about anything.
Of course, used kitty litter might help give it that “smell” of the battlefield… [:o)]
So actually practically anything can be used.
Limited only by your imagination. If your really keen you can make your own bricks, for broken section of brickwork you can pour plaster of paris into a shallow tray and let it set. Once set scribe your brick pattern onto the surface, and break it up, touch up the scribing on the broken inner surfaces, and paint.
Aquarium Rocks work well, too.
Take a walk through your neigborhood…you’ll be suprised what you’ll find.
Rubble.cat litter,dust from the side of the road,small rocks…use your imagination!I once used very fine dust from used “dry sweep” from where i work to dust down the running gear on a panzer IVd!
Yup, thanks
