Is dust ever a problem when it comes to dios? After a few month, does your dio get all dusty and unattractive? How do you get rid of dust? Do you put a clear case around your dio or do you frequently clean your dio (sounds painful, especially if you have a lot of dios)?
you can use compressed air to blow dust off of your diorama
I carefully brush them off with a big, fluffy make-up brush that I acquired from the wife.
but what about breaking off the antenea and fine parts or dustind off the snow or sand or that type of stuff
The key is above.
For this reason, I never consider a dio finished.[:)] You continuously work on it forever.
I use compressed air to gently blow off dust every once in a while. Its kind of a pain, but what can you do. Its too pricey to make cases for every dio.
It definitely is. I’m considering building a cabinet for my models, one big case.
