Hmmmm;
Does this bug you ? A beautiful ship model .But , The wheelhouse is empty and crummy looking , or you can see clean through the vessel to the other side at the ports ?
This is a solution I have used for years . On most ships I run a panel right down the center of the hull . It is painted completely top to bottom and the length with Flat Black paint . This also works on Vehicles and Armor
Now for wheel houses .You can paint the windows . I personally think this looks unreal , no matter what color you use unless they are the engraved type . Even then there is a fix . Frost the clear ports with a layer of styrene glue before taking them off the sprue ( if they are seperate parts .If they are just holes then put a strip of .010 styrene clear sheet frosted , behind them .
Now for those wheelhouses in larger scale . Sheet plastic , again .010 clear styrene strips . Frost the strips with model cement ( the liquid type ) ( I find Testors or plain old lacquer thinner to work best ) .One swipe in one direction with a wide brush is all that’s needed .
Result , even in 1/48 or 1/32 the windows are there .You just can’t see the empty space behind them . This has been used by me for many years with many clients happy because they didn’t want the detail inside but wanted light to pass through .
T.B.
