How much MM Semi Gloss Lacquer To Add To MM Flat Paint To Make It Semi Gloss?
How much MM Semi Gloss lacquer should you add to MM flat paint to make the paint finish semi gloss?
Thank You,
DJ
Ummm, none? [%-)]
Do you mean how much flat do you add to the GLOSS to make it semi-gloss? I would start at 4 pts gloss to 1 pt flat and adjust to taste.
