I’m hitting “reply” to my own post, hope I don’t go blind!
Recently, I have been working with the “salting” technique, which I picked up several years back in FSM.
As I am working with German WWII armor, there were two main paint schemes: Panzer Grey [Dunkelgrau] til about 1943, then the Dark Yellow [Dunkelgelb]. To show the weathering of vehicles that were oversprayed with the Dunkelgelb over the Dunkelgrau, here is what I’ve been doing:
First, spray the entire model Dunkelgrau. Assemble, leave the tracks and smaller details off until later. Once you have the basic structure of the model together, mask off any openings to the interior if you have worked on superdetailing that. You might hit the exhausts and other badly rusted metals with a base of brown or rust color.
Now, here is the trick: Take an old brush, and some water, and some ordinary table salt. Along the edges that would have received the most wear, you first dip the brush in the water, then into the salt. Put the salt onto the model, leaving large deposits of the crystals to dry. The salt and water mixture should be a bit of a sludge/goop, and like I said, make sure you’re leaving crystals behind stuck to the water. Allow to dry thoroughly.
Then, once the model is completely dry, you spray a second coat, this time Dunkelgelb. You let the second coat dry thoroughly, usually overnight. One the second coat is dry, now comes the fun part! Using an old exacto blade or a toothpick, you fleck away all of the bumpy salt that is covered with the new coat. Voila, the old grey paint scheme is peeking out at you. Keep going, and once you get all that salt off (you can leave some salt deposits down then hit those raised areas with mud or rust color), decide whether you want to go further. If you do, take the back of the blade and scrape carefully on all the edges of the model, flaking off the top coat to expose the color underneath.
Instead of the exacto knife or the toothpick, you can instead use an old toothbrush. If you get to the point that you aren’t getting the salt off to your tastes, you can (GENTLY!) scrub off the salt under the running tap; the water melts the salt, and the toothbrush pulls off the “scab” of new paint left behind.
This salt technique works for aircraft as well, as was in the original article, to show the paint worn down by sandblasting effect from the props on the leading edges, and wear and tear on the paint from the pilots and crew getting on and off the aircraft.
I’ve also gotten some really incredible effects with a yellow undercoat and then a white overspray, to simulate the whitewashing wearing down as time passed. You could also use an undercoat of “spot-rusting” here and there with a rust color and then overspray with the main color.
This is a technique that takes some practice. Use an old model that you just aren’t all that happy with and give this weathering technique a try. Your final work should be with your weathering washes or pastels or Rustall or whatever. I find that the surface left behind by the lost salt technique offers excellent “purchase” for your weathering materials.
Hope you guys give this a shot. You could actually also use masking compound to hit the model with before the overspray instead of the salt, but the abrasive nature of the table salt does much better, in my opinion, of mimicking the flaking of a hasty paint job over a base coat.
If you try this method, you will be quite pleased with the results. If you are wanting a new tank right off the assembly line, however, just go with a virgin coat of paint.
