With one of these !
This is the resin bomb sled that came in Verlinden’s detail set for the Ar 234B. It’s one solid piece of resin, and BEAUTIFULLY cast !
I painted it with a mixture of enamels. The base coat was a mix of MM Wood and RAF Earth Brown. One wash was a mix of that color with black for the shadows between the boards. Additional washes of Dark Earth mixed with MM Leather and Insignia Red provided the color variations in the wood. The sled was drybrushed with MM Wood after dullcoating. The nails, nuts, and bolts were painted with a mix of MM Steel & Flat Black, and drybrushed with Steel. Areas around the nails & bolts received a blackened brown wash.
This will be displayed with my finished Ar 234, with the bomb on it. The casting of this part is so nice, and it takes washes & drybrushes so well That I had to post pics of it without the bomb.
My Ar 234 is moving forward, and has been decalled. I will be applying the washes Wednesday, so I may be finished within the week.
Thanks for letting me share the pics with you !
