Hi all I live in australia and would like to know how to make a tree in 1/35 scale
I haven’t tried this yet, but you take a good looking tree branch (you choose the size) and put some kind of glue mixture on it (not sure what but I think it’s its water and white glue), then you roll the branch around in something like ground-up parsly, or I think some people use the leaves out of a teabag (green tea)
Your 1st post! Welcome to FSM!!!
If your library has any back issues of “Model Railroader”, you can search through them for many articles on tree construction. They usually cover a lot of scenery techniques in good detail.
Roots of woody plants work great for scale trees. The bark layer of roots is very fine and is a scale representation of bigger trees. The reason I say woody plants (plants that have bark) is that the root branches will have bark as well as the trunk of the plant. The very fine root structure of some plants makes for some great branch configurations and if you roll them in glue as was mentioned earlier they will pick up more material, making the tree look a little fuller. Branches used as trees tend to have an out of scale bark and because usualy the moisture content of a branch leaves it first (before roots) the smaller, more fine branches tend to break off, leaving too simple a tree for my likes. Roots have finer tendrils and the closer to the end of the root branch you get the finer the tendrils will be, giving your scale tree more branches.
The bark on roots will tend to reflect the bark of the tree. So if the tree you are looking at has smooth bark, the roots will tend to have smooth bark conversely rough bark will usually yield rough bark on the roots.
If you go and look for uprooted trees or you pull woody brush or weeds you will notice in the root ball a variety of very interesting shapes. You can get some really nice trees from some plants. Knock the dirt off and rinse off the root. Set it out in the sun to dry. This will do several things, it will harden and dry the root material (roots have a higher water content), They will lighten or darken depending on the plant. As they dry in the sun the bark will stand out a little more. Raising the detail and adding to the “scale bark” effect. If necessary you can make it pop a little more simply by drybrushing the tree material.
Don’t be afraid to mix in some nude tree with your leafy stands. If you at nature you will see dead or bare trees mixed n with live full ones, and in some cases you can leave whole sections of tree bare and while the rest may have whatever leaf material you want.
This is much easier and I think more realistic than some of the ingenious braided or twisted wire with putty coverings. This is a real tree and has the characteristcs of said tree.
Depending on battlefield conditions and recent barages you can have bare trees in the middle of summer. Add some “scorching” or in some cases actually char the tree and use it. to a onice effect. Rather than snipping branches off, tist and tear the branches to show damage from shelling. You can twist it and give it a frayed look by dragging it along concrete. while it is still damp or still has a little moisture left in the cells.
Goodluck.
Thank you all for your reply to my problem i have printed all your ideas and am trying them all on different bits and pieces as for the model railroad books we dont get alot of them over here but have bought some from my hobby shop
once again thank you all[:D]
You could try something called “lichen” ( I think that’s what it is called) You find it in model railroad accessories. It’s a dried moss or something. It has a fine texture but is dense. We used to just trim off a piece and glue it on a twig for architectural models. Instant tree. It isn’t 100% realistic, but I don’t know what you’re going for. Even for small shrubs - it will work.
Good Luck
hmmm, thx Renart!
There is an article in one of the FSM mags about making trees. I’ll see if I can locate that issue, and let you know.
I think that I shall never see
A poem lovely as a tree.
A tree whose hungry mouth is prest
Against the earth’s sweet flowing breast;
A tree that looks at God all day,
And lifts her leafy arms to pray;
A tree that may in Summer wear
A nest of robins in her hair;
Upon whose bosom snow has lain;
Who intimately lives with rain.
Poems are made by fools like me,
But only God can make a tree.
– Joyce Kilmer
We now return you to your normal poetry-free forum…
“World war II dioramas” (osprey book) has great tips for making trees and basically any groundwork and tall grass.
-DJ
Hi Danny,
A few months back I posted this link where I described my way of making a tree. This is is not the best method there is but maybe worth a try. You can also find ways to improve it by using different materials.
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=28027
Good luck.
I read that link, that is AMAZING[bow]! that really is a niice looking tree, you have a fantastic imagination[yeah], I am going to try that this evening, and to think I had all that stuff laying around, I am going to have to start thinking more “out of the box” as they say, when you publish a book I want to be the first to buy so I can learn all your secrets, LOL[;)].
Be good & have Fun,
Bill
