Hot link Question
I was trying to insert a hot link in a reply and due to the new reply format I am unable to.
Is there a trick for links like the way pictures are inserted?
First, do you see the link icon?
If you do, then to create a link, you first need to type the text for the link and then click on that button. That should display a small window where you can enter the link url.
FineScale.com
To create a link using forum code, type {url=http://www.domain.com/}link text{/url} but replace the {} with (square brackets).
FineScale.com
You can also use HTML, like this: FineScale.com when you use the HTML mode by clicking on the HTML button.
Cool, tried the 1st way on testing section. Worked great.
Thank you Mr. Voss
