Thanks for the posts guys.
Keavdog. These big beauties are being done for HK Models for them to use when having a stand at shows in the UK. Once done, they are displayed for an evening at a friends’ Italian restaurant and then carefully packed and stored in protective wrap and boxes for travelling and kept safely in my house. Houseguests get a look if they request it. They are mine, but donated by HK.
I do like putting my build of these up here as I do hope to inspire someone to have a bash. They are not hard kits to build but they are large. With this in mind HK have designed these kits with detatchable wings which once you have invested, built and painted you can easily store safely and bring out when you want and for travel purposes too.
Well… most of model kit building, or the thing that takes the time is painting…
I did have trouble with 1 man army insignia masks. I am not sure why, but I am sure that it is my fault and also the fact that the insignia don’t really follow panel lines on the B-25 which help with accuracy of placement. I also had issues with Maketar mask insignia too. It must be me!
Grey coat needs patching. Need to work on those handling skills and cut my nails!!
Corrections needed!!!
Hmmm! Maketar masks for wing are bigger… Not by much though and they seem to be the same size as the kit decals…
Is that… or is it the angled panel lines… is it me?
Right! lets try something different…
THis has to be me… Just got to be!
Ah Ha!
Ok… Moving on to 1 man Army stencils.
According to the stencils the fuel tank filling caps have a red circle around them and black text. These are separate masks.Also I realised that this was not going to be easily done, despite the masks, so I went image fishing on the net. All the current restored/flying B-25 seem to have the entire filler cap painted red. I went down this line…
Don’t forget plenty masking to catch paint!
Do the text mask once the red is dry along with masking to catch paint and…
Again with the insignia masks!
Extra making to make sure paint does not seep into cracks…
… Both sides…
More stencils…
Following instructions and getting better. These are actually readable. You have to be very careful when placing. Read instructions and use some of the spares to practice on your scrap kit!
Fuselage mostly finished. Time to do nose and underneath parts!
Re masking for underside hatch/bomb bay rim painting.
Armament added
Still forward facing side guns to add and upper nose section which will be the last thing on the fuselage. Also nose art decal(s) to add as well as repainting demarcation line around front of nose.
More next time.
