I am looking to get canopy masks for my HK Models B-17F in 1:48 scale. I note that Montex has a mask kit (MM48520) for the B-17G. Does anyone know if there are any issues with using this mask kit on the B-17F?
Thanks!
Thanks!
Not sure re: the G vs F but poking around Squadron has a set of masks for your kit at a good price considering how extensive it is.
I was thinking there might not be a 1:1 match in the window shapes, but in looking at photos of an F and a G, I can’t pick out differences other than a lack of windows in the waist gun positions on the F. Would not be a big deal since you just wouldn’t use a couple of masks.
@keavdog thanks for sharing. One of the reasons for wanting the montex set was for the insignia masks.
@Aggieman thanks for looking into it more for me. That makes me more comfortable in getting them. As I told @keavdog I like the idea of masking the insignias.
Is the masking used for covering off parts that you don’t want painted while painting the model?
Yes. Montex Masks are a vinyl tape cut to fit the kit in question, whereas other companies like Eduard use a tape more akin to Tamiya’s yellow tape. These are generally pretty easy to work with, although I have come across an occasional set where it appeared the guy cutting the masks had never actually laid eyes on the actual kit.
Agreed. I typically make my own masks from Tamiya tape for most of my planes but bombers like the B-17 and the Beaufort (building for the Battle of Britain group build) I like to use a precut mask. I’m also interested in masking for the insignia just because I think that it looks cooler painted on than it does as a decal.
I’m hoping to get a cricut or a silhouette so I can mask for the insignia and the unit/squadron numbers.
@dadoffour I’ve given thought to acquiring a Silhouette for that purpose. Where do you get the template? Perhaps a scan of the kit’s decals?
