I’m working on a V-22 Osprey and it calls for flat black in the wheel wells. I like to highlight the wheel wells to show depth but I’m not sure what color to use over the flat black? I experimented with gray but it didn’t give the effect I was looking for. Thoughts?
Add some red-brown to your black and it will give a nice faded black look without it being too stark. Dry brushing with a dark gray or neutral gray should look good too. Deck Tan or Buff added to the black would work too.
If you have molded details you want to pop, mix some grey oil washes to add some depth. When dry, then dry brush as Nathan mentioned. I found that a light wash of yellow ochre oil paint will fade a bit and separate the molded detail against the black.
I seldom use flat black for actual surfaces. I only use it for places that are an orifice where nothing should be visible. For all else, I soften the black. I find panzergray is a good very dark gray to either use as a weathered black or to mix with black to soften it.
One possibility for wheel wells is a very feint, light wash in just a few areas of red, to simulate hydraulic fluid. I sometimes do a very light wash of this on the gear too. It has to be absolutely minimal, however.
