Oh great and wondrous gods of the double action AB I humbly bow to you
[bow]
I just used my Badger 155 for the first time…. see “109 progress…” in Aircraft section. My 49 year old muscles only remember the single action AB last used so many years ago. As I said in the other post… this will be a fantastic tool once I get used to it. But to save time with experimenting, I have a question or 2. To get the smallest and/or sharpest feathered edge of the splinter on a wing or the small mottles on the vert. stab., what is the best combo of paint thinning and pressure? And, so I can visualize the process, how close to reckon you hold the AB from the surface and do you spray obliquely or perpendicular to the surface.
Oh… yeah… and gods… please don’t smote me if already asked and answered…
I’m not sure if I understand what you are trying to do, but I’ll assume you are trying to get the finest line out of the AB? for this, I thin the paint a bit more than you normally would and drop the psi down on the compressor (10 psi or so seems to work for me).
with my Iwatas I do put the AB VERY close to the model, basically point blank where the AB touches the model at a perpendicular angle.
I am certainly no god when it comes to AB but we have plenty in these forums. but the God of PRACTICE can’t be beat. Practice is something that all the advice in the world can’t replace! Experiment with different thinning ratios and pressures. Good luck!
Well spoken!! Practice!
I also use a 155 and 10psi might be a touch low for it to atomize properly, try it but if the paint spatters or spits raise it a PSI or so until it comes out as a fine spray.
And as was already mentioned close to the model (1" or less) and thinned more than normal paint. You;ll probably have to play with this until you get something you are happy with. an empty milk jug is nice to spray onto when you practice, lots of curves and flat spaces to get a feel for the technique.
And you won’t need to pull the trigger back much if you want a fine line or mottle. Just a touch.
Oh yeah and in case it hasn’t been mentioned yet, practice!!! [;)]
—edit—
and of course you will want to use the metal color cup, and not very much paint in it either. If it is a custom color you will be spraying mix it in the glass airbrush bottle and put a top on it and keep pulling out of that to feed the color cup. You just want enough paint in it for a few squirts.
Good luck to you!!!
Thanks for the tips. Now that I have a good starting point i will practice, practice practice.
