hguc Powered GM work'n'progress
mmh…
One of few exceptions between my zeon army
Ok this way i’ll try to do no modding on this (only if indispensable) [8o|]
The mech come from 0083 oav .
The kit is pretty nice and have a great posability.
Unfortunately the parts division don’t aid the painting for movable parts, so the only mods needes is focused on this.
Here the snapped and dusted kit (brought 2 or 3 years ago)
[![Photobucket|364x470](http://i405.photobucket.com/albums/pp139/bsyamato/gundam misc/DSC_2194.jpg)](http://s405.photobucket.com/albums/pp139/bsyamato/gundam misc/?action=view&current=DSC_2194.jpg)
Starting the disassembling
[![Photobucket|363x236](http://i405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/100_1267.jpg)](http://s405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/?action=view&current=100_1267.jpg)
[![Photobucket|367x511](http://i405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/100_1273.jpg)](http://s405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/?action=view&current=100_1273.jpg)
The head is great:
[![Photobucket|375x244](http://i405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/100_1264.jpg)](http://s405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/?action=view&current=100_1264.jpg)
On the arms the first obstacle, the elbow is fixed between foearms by a ilynder pin:
[![Photobucket|389x239](http://i405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/100_1259.jpg)](http://s405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/?action=view&current=100_1259.jpg)
I semoved ll pins and blocks to allow a separate painting of differents pieces
[![Photobucket|392x247](http://i405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/100_1262.jpg)](http://s405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/?action=view&current=100_1262.jpg)
the same elbow joint need some adjust, no pcb parts inside, the movement is done by the black abs plastic that rubs with other abs piece. i’ll try to resolve this putting a little washes betwueen the pieces, this weekend…
At the next [blkeye]
interesting build.
Ron
Thanx Ron
Little update, advantage of Italy 150 unifycation years celebrations… [^]
starting knee separation:
various pins prevent a good manipulation for painting, i’ll build a pit to make pins unnecessary
[![Photobucket|344x268](http://i405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/100_1406.jpg)](http://s405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/?action=view&current=100_1406.jpg)
placing various piece of plastic (tamiya glue used, CA glue will make a too rigid structure that can be break by legs movement)
[![Photobucket|274x233](http://i405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/100_1412.jpg)](http://s405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/?action=view&current=100_1412.jpg)
[![Photobucket|277x183](http://i405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/100_1414.jpg)](http://s405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/?action=view&current=100_1414.jpg)
[![Photobucket|273x185](http://i405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/100_1417.jpg)](http://s405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/?action=view&current=100_1417.jpg)
lots of test fitting needed, the lower part is done, wating tomorrow for glue dry for finish.
The upper legs will be more difficult [:(] … soon updates
That’s a great idea! Thanks for the tip. :slight_smile:
m@
happy to know that it is useful [;)]
and… after gluing the lower legs i can say that it’s work good! (first time i use this tip).
The blocked knee joint it’s a problem that have even others hguc i will build in future (hazel and rx-79g sure)
the results: the fitting is good
[![Photobucket|333x316](http://i405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/100_1428.jpg)](http://s405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/?action=view&current=100_1428.jpg)
[![Photobucket|321x260](http://i405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/100_1429.jpg)](http://s405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/?action=view&current=100_1429.jpg)
the chest is glued, ready for the total sanding as i used to do and panel lines engraving
[![Photobucket|326x257](http://i405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/100_1427.jpg)](http://s405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/?action=view&current=100_1427.jpg)
head star painting, inner parts painted with humbrol 144
[![Photobucket|339x239](http://i405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/100_1439.jpg)](http://s405.photobucket.com/albums/pp139/bsyamato/gundam misc/powered GM/?action=view&current=100_1439.jpg)
that’s all for today…
winds of war beginned in libya… i’m about 400 km from there [:^)]
with this type of kits you can use the c-joint modification for easy of seam line fix and painting.
the below is the parts breakdown of HGUC GM Light Armor Ver. Ka that I’m building…
hope this of some help.
thanx dj898 but:
  1. In this kit , the elbow parts includes the joint for the shield, that provide to work good as pin for the whole rotation joint. [:)]
  2. I had forgotten the c-joint modification … [:'(]
i can try it with the elbow middle parts.
Man, I really wana build a gundam kit but I dont wana deal with white, cable rings, or yellow… and that sort of cuts off most of them ugh
[:D] smeagol , this gm it’s not perfect white, fortunately is light light light gray.
for cuts, it’s just my mania, you can build and paint thr powered gm whitout these cuts, theres lots of masking solutions .
