I’m new to the photoetch world. I just received a sheet of 1/72 photoetch material for an Airfix P-51D, Color Zoom if you will and it is marked “self adhesive”. When I opened the package, I thought there might be a paper backing, when peeled away would reveal the adhesive surface. That is not the case. It just looks like a brass metal surface on the back. Nothing sticky to the touch. (I only touched it lightly)
Question: In the directions after cutting the part away, it says to just apply pressure on the model surface to adhere the part. What about as I cut it away on a cutting surface-won’t the part stick to that? I may be missing something here.
