Help with F4J Phantom
Hi All
This is not my usual thing building aircraft! but have had a Tamiya Phantom F4J in 1/48 the problem i am having is finding what the inside of the cockpit looks like & colours the control panels any help would be great. I build amour but am going to give this a good try.
Many Thanks Alan[:slight_smile:]
Here’s a site that I have found that had a some cockpit views. It might be a G model, but should still should be the same colors.
http://www.aircraftresourcecenter.com/
Go to where it says walk arounds and it will be under the jet section. Hope this helps.
I think that might be a Hasegawa F-4J if it’s 1/48. Tamiya does make a 1/32 kit of the F-4J though.
Found this one here… Don’t know if it depicts the same cockpit as the one on your model… Hopefully it will be close enough for ya to give you some idea…
Hope it helps
Paul
Try here and scroll down… Pics are black and white. Overall panels are light gray and dials and instruments are black.
http://members.chello.nl/m.waterloo/f4j-panel.html
Melgyver Yes i see what i did & i did mean to put 1/32.
To all of you that passed on the infomation to me many thanks Alan.
