Help. Uncure??
I used some Uncure to debond CA. It left a white residue and kind of etched the styrene a little. Is there a chemical that will remove the white stuff? Will it cause a problem with paint adhesion? By the way, the rudders on a B-25 look funny when they are installed upside down.
Another lesson learned: “When all else fails, read the instructions.”
[(-D] I’m sorry but that’s pretty funny!! I bet the rudders did look a bit…off. Been there and done that. Anyway, I’m sure you found out that Uncure (as well as de-bond) will eat everything down to the plastic. Been there and done that too. Your gonna have to repaint the area. Just clean the area well with alcohol first.
Andy
Hey, that’s the first rule of the aircraft mechanic (or "When all else fails, read the manual).
(the second rule is “If it don’t fit - get a bigger hammer”)
Third rule: If it still doesn’t work after the implementation of the field mod…blame the new guy.
