can anyone give me some advice? i’ve just built a sabre and thought to save mixing paint i would use auto rattle cans for the silver finish. BUT it has sort of eaten into the paint leaving a orange peel finish that is quite deep.hope fully someone will have some tips to help me rcover this model as the cockpit alone took me a week and a half to do. If i can’t repair it i might just have to try the airplane junkyard dio iv’e had in the back of my mind for a while.[:)] cheers
If you sprayed an unprimed model with Lacquer based Automotive touch up paint & it etched into the plastic, it’s pretty much a lost cause. If the orange peel came from painting to close or to heavy, you might be able to sand it smooth & repaint. At worst, strip the paint & start over.
Regards, Rick
Lets hope you did’nt use lacquer paint. If not, like Rick suggested, get out the sandpaper.
Good Luck![2c]
unfortunatly i did, but i used a plastic primer. oh well airplane junk yard it is. Damn shame the cockpit turned out so well[:(] thanks guys.
