help painting
ok i am 19 and been doing model cars good painting and stuff. but i tryed to paint 1/35 scale figers and the paint dose not stick i tried regular/ with black primer/ and the paint i use model master paints. any help would be appreciated i tried and tried
What figures are you trying to paint. Are they Plastic, resin or metal.
the plastic 1s like tamiya 1/35 scale guys and there gun kits
One tip I can offer is to soak the plastic for a while to get rid of the releasing agent on the plastic. That could help, especially if you’re using acrylics. These oils on the plastic may reject the paint. As a practice I usually soak all the sprue trees from a kit overnight using dish detergent. I know other modellers use other products like brake fluid, but I’ve never needed more than just detergent. Also make sure your paint hasn’t settled on you with the pigment seperating at the bottom of the jar. Give the jar a good shake and stir with a toothpick prior to painting.
I like to prime my figures with the Tamiya rattlecan stuff
ok thank u the paint i use is model master enamel paint.
These figures are probably vinyl. There has been a thread recently about painting vinyl. See if you can find that thread. There is not much that will stick to vinyl.
