Help needed on sdkfz 250 3 :
HI Guys
I have not posted in a while, or worked on the big tiger 1. Instead I have been working on my 1/6th scale sdkfz 250/3.
I started this project over a year ago and it’s still in gray primer and I am working on small details.
this is what I need help with. I know the hinges are not correct, but I have to work with what I have. I added small bolts to them for some extra detail.
I found this picture for the side hatches
mine
but the top is another story. I just can not find a (clear ) picture of the latch for the top engine hatches.
anyone have a good picture ? It would be greatly appreciated.
Thanks in advance
CG
PS: when I get some time I will do a project log for the 250/3
I suspect the engine hatches used a key lock like the SdKfz 251 series.
However, if I can ask a question: granted you haven’t replicated exactly the hinges – but I should think that adding the extra bolts just adds to the inaccuracy. Why not omit them or go whole hog and replicate as the originals?
I know it’s a balance between “good enough” and not “good enough” – I do plenty of scratchbuiliding myself – however I wouldn’t have added the bolts.
yes, I think your correct. I hate the look of the hinges. There are a number of “inaccuracies” in this Armor Hobbies kit. And at 1/6th scale they stand out.
I can get these
for about $5.00 each, cast resin… They look about right. BUT, it’s going to be a lot of work getting them installed… I wonder if I will ever finish this thing !! I am going to order the hinges tonight.
Do you have a picture of the 251 key lock ?
CG
Do you have the ability to buy one and cast your own? On this site, look at the SdKfz 250/5 under German, half-tracks
http://protein.informatics.indiana.edu/jaalbrec/panzerdb/img/walk/pdb.html
It’s really just a tab which covers a key hole. Here’s one on a 251
http://svsm.org/albums/Sdkfz2511/IMG_2263.jpg
Good luck to you
Much thinks T26E4.
that is just what I am looking for. That machine is a sdkfz 250 “neu” but I would guess it is the same.
the same sort of " thingie" that can ( just ) be seen in the picture…
I can not cast anything, but I can make myself one of those !!
I ordered the 10 hinges I need for the machine… More money and time, but it’s for the best…
Much thanks
thinks for the links and your help.
CG
POW
After looking at these pictures I noticed the front edges of the two engines hatch doors are not “rounded” to the same degree… I don’t think I will ever finish this %^*&@# thing…
MUCH THANKS T26E4
CG
Hey: take a look at this new gallery (303 detail pics of a 250/5)
http://svsm.org/gallery/sdkfz250-5
WOW T26E4 !! much thanks
you found a gold mine of 250 pictures. I just looked all them over, I have many new ideas for the project.
Thanks again
CG
With the help of those “gold mine” pictures, the engine hatches are looking good
replacement hinges on the way…
I moved to the rear door.
this is what the stock kit looks like.
I did:
new hinges
rivets
tarp hold down
door handle
I will take this thread no further. I will give you a complete A to Z build when I have time. As i said before, I have been working on this thing for over a year and have lots to show you…
CG
