Help Need Tamiya paint equivalant to RLM75
Just as the post says, I’m getting ready to paint my 109 and the instructions are calling out for grey RLM 75 and all I have are Tamiya paints, not sure which one to use. I was thinking of using either med. grey or neutral grey, not sure. Also I"m assuming/hoping that their dark grey will work for RLM 74 , if not what color do I use for that also? Thanks
Unfortunately, there is no direct equivalent to RLM74 and RLM75 in the Tamiya range. For the 75, I mix Tamiya XF-54 and XF-51, comes pretty close. Can’t remember what I used for the 74. Here’s a link to an excellent reference color chart from IPMS Stockholm, HTH!
With a bit of cross-referencing (RLM>FS>Tamiya) I would say XF-54, RLM75 = FS26231 = XF-54. I would advise you use Mk1 eyball to verify this. You may notice that some cross-references will suggest FS36231, this is also correct, the 1st digit only denotes the finish, gloss matt…
Some usefull links;
http://ipmsstockholm.org/colorcharts/colorcharts.asp
http://www.colorserver.net/
http://www.ipmsnymburk.com/tamiya%20mixing/RLMwithTamiya.pdf
http://www.paint4models.com/index.html
Looks like Daywalker got there first (& knew more about it).
Thanks guys, greatly appreciated. I just made things easier for myself and went and got a bottle of Model Master Acryl RLM 75.[:D]
