help me please
alright well i got those remove before flight flags from someone on here who was generious enough to send em to me but no that i have then it says to hang them with some wire the problem is that there 1:32 scale ones so i have tried every type of wire down to 20 thousands shear wire and it is still to big what would you all reccomend.
Try 2lb test fishing line if you can get it over there.
If not, find a lovely young lady who will part with a few strands of human hair, it’s perfect.
You could try taking one strand from a womans panty hose.
Joe
Given your address, I’d be careful which lady I asked.
have you got an old pair of walkman headphones ? slice the plastic cover off the cord and inside you’ll find many thin strands of fine copper wire ! I think its called fuse wire .try finding it seperately in hardware stores or you could even take apart old broken appliances such as alarm clocks or radios.
or ,how about stretched sprue ???
Actually those are the 1/48 scale versions. The 1/32 scale flags are about half again as long.
As Olsen mentioned, find a piece of speaker wire or something along those lines. It is usually stranded #22 or smaller and each of the strands are tiny. They work quite well for things like that.
