Help finding a specific model
Hoping someone here can give me a hand. My coworker used to drive a tow truck for BP fuels when he was younger and wants to build a replica of that truck. Does anyone know of a company making a plastic model kit of the 1968-1970 Ford F-350 homles wrecker? Done some digging but havent had much luck so far. Thanks
Here a link with the truck in question
http://davidsclassiccars.com/ford/109688-1969-ford-f350-4wd-holmes-440-wrecker-nut-amp-bolt-restoration-f100-f250.html
There is a shop in St.Paul, Mn that has old kits. Not sure if they have one but you can give them a try. Its called Scale Model Supply. Good luck hope you find what you are looking for.
Maybe this
Plus this (pricey)
Don’t know about availability, but there was a '67 Ford with a service body. Looks like a 4x2, but single rear wheel.
Main differences between '67-'72 was the grille and trim levels. I had a '70 Ranger back in the day.
Thanks for the info, sounds like he may have to get the truck and add the towing gear onto it from another kit.
I’d do what keavdog suggested and combine the truck with the wrecker
That’s what I did to make this International Wrecker
Depending on his skills, might be able to try scratching the tow bed. Most were built up from flat plate. The hardest thing would be the boom and winches.
