Heller T-6 D/G Texan
Howzit to all of you out there,
I need help, have any of you built the Heller (80434) Texan and found that the rear canopy doesn’t fit. In fact, it belongs to a different Mk Texan? And if you did, how did you correct for it? I asked Heller in France to send me a replacement part, but when it arrived today, it was the same part. So it seems to be that 80434 will always have the wrong rear canopy. The part number on the tree is 53.
Looking forward to hearing from you.
Mirage.
Hi Mirage, i am sure there is a vac form canopy for this kit either by falcon or someone like them, i’ll have a look around later and see what i can come up with on this. Greg
I made the academy one which is a copy of the heller and there is no problem.
maybe with a bit of sanding it will be ok
Thanks guys,
I did order a Falcon vac form set through my local model dealer and I’m just waiting for it to arrive, but sanding down is definately not an option in order for it to fit. I tried!
uuuuuuups, you had a problem here…falcon is great anyway so good choice…
