heinkel 11. 1 paint color ?
Hello im building the Revell 1/32 heinkel 111 the paint call out is pretty poor i like to use modelmaster enamels does anyone know which paint codes are used for the german camo scheme. we dont have a hobby shop and i need to order over the net thanks for the help .
Ok Tom …for which scheme are you modeling .?..Desert?(north African )…or the European theater. ?..is this kit #5628 ?
5-high
Tom . I’ll have to look for my color code library for model master to RLM codes .I have them some where …give me an hour or so and I’ll post them for yaa …I’ve build a few of them …in the beginning I too ran in to the same problem. I’ll get back to you once I find the paper [;)]
5-high
Sorry for the late reply Tom
RLM modelmaster colors that you’ll need are as follows :
Cockpit color:RLM 66—FS-2079 M.M
LIGHT OLIVE :RLM 83 (the darker one is RLM 80).FS-2092 FS-2089 MM. I used RLM 83 for all fuselage interiors marked ( M)
The spinter camouflage colors :
White -FS-2143
RLM 04 yellow -FS-2072 MM
RLM 71 dark green -FS-2081 MM
RLM 70 black green -FS-2080 MM
RLM 65 light blue -FS-2078 MM
RLM 24 dark blue FS-2074 MM
RLM 23 red FS-2073 MM
I hope this helps Tom .let me know if I can help with more .cheers.[t$t]
5-high
thanks for the help sorry for the late response
If you are doing the P-1 version of the Heinkel, the cockpit color should be RLM 02. The Germans didn’t start painting the interiors in RLM 66 until 1942 I believe.
