This is the Hasegawa 1/72nd He 111Z. I am building this for the Twin Boom GB but thought I would do a WiP thread as well. I started this 2 weeks ago and its been slow going as I am doing quite a bit of scratch building on the insides. I have only done little bits of scratch building in the past, so I am hoping for the best. I am also adding an Eduard Big Ed set and CMK resin wheels and two engines.
I originally built the Italeri kit many years ago, but that got badly damaged with many of my completed builds. When it came time to replace it, I opted for the then newly released Hasegawa kit.
This is the kit in question.
I started out on the rear compartment. The Eduard set includes the radios. According to their instructions, a set should be fitted to each fuselage. But only the left fuselage had a radio operator and antenna, so I am only fitting radio’s to that side. The spare parts have come in handy for some of the bits that Eduard have missed. I have added a compartment floor and the fuselage detail is where the plastic curves away to form the wing join. The ribbing is a bit thicker than the kit detail, but its what I had to hand. Here you can see one fuselage done with the other before I touched it.
Then last Tues I got this area painted RLM 02. I wanted to do everything that was 02 at the same time, so I had to get the undercarriage wheel wells and everything else sorted. It then got weathered and I added rails that I think are for the gunners feet.
Another area where I am deviating from the instructions is the beam guns. According to the instructions, that are fitted to each side of each fuselage. And most kits of this aircraft also show this. The Eduard set also has MG ammo holders for both positions. But from what I have read and seen, only the outboard windows carried MG’s. This makes sense as inboard guns would run the risk of putting a burst into the other fuselage. So I am positioning the holders in the appropriate place. This is more guesswork, like the radio’s, but it makes sense to me.
Then last night I got the cockpit painted RLM 66. I had already added the none coloured PE.
I also have the wings together with wheel bays fitted and the two resin engine mounts.
I had originally intended to put the resin engines in the outer right and centre engine. But the engines are designed for the angled leading edge of a standard He 111, not the straight edge of the Z’s centre wing. So I had to change my plans a bit.
Next up will be to weather the pit and add all of the rest of the PE as well as the radio kit for the back.
All comments, suggestions and questions welcome.
