Hasegawa's B5N2 Kate, my entry for the Japanese Group Build XIV
I’m ready to make a start my Kate from Hasegawa, only after I take pics of my completed Do 335 from Tamiya.
Only one part is rattling inside the single plastic bag, a prop cone. I don’t know why Hase doesn’t take the Tamiya and many other campany’s approach of individually bagging the sprues
Scheme chosen is Pearl Harbor’s 3I-318/Black 18. Since the belly is in NMF, I’m lead to think the pre-Pearl Harbor scheme was overall in unpainted metal, am I correct? If not, I’ll go for the green camou with brown mottling.
They due to materials and manpower late in the war the stopped painting the undersides.
Well, instructions for this one say the undersides should be left unpainted, for Pearl Harbor. I’ll look around for other Kate builds to check for NMF schemes.
Edit: Thanks for your response on the GB topic! Very helpful.
It is possible that, the undersides were painted silver instead of a NMF. As Keavdog pointed out, the Japanese didn’t start leaving the undersides in NMF until much later in the war and for the reasons he specified. Also, the IJN units that DID have NMF undersides, I’m pretty sure were land based units.
I would think that any carrier based aircraft would be painted in something, not for any other reason than to prevent corrosion. Because of the harsh salt air/water environment carrier based aircraft operated in, they couldn’t NOT paint the airframe. Of course that’s just my opinion. As you mentioned, your research might shed a different light on this.
A second point to consider, is that before the war got going in earnest, these aircraft were painted overall silver, a black cowl and a red tail with white ID numbers and letters. It is entirely possible, as the Japanese prepared to attack Pearl Harbor, that the green was added as some measure of camouflage.
Just a couple schools of thought as to why the undersides were silver? I’m sure others know more than I so there’s that. No matter what you decide, it’s your model and it’s a hell of a beautiful kit!
Looking forward to seeing this build progress!
Cheers
My motto: Ignorance is Bliss :stuck_out_tongue_winking_eye:
Looks like a fun project.
I had that kit but sold it. I think it was the size. I did not know where I would display it if I did build it. I have since downscaled to the both the Airfix and Hasegawa versions in 1/72. Oddly, I also had and still have Hasegawa’s 1/48 B6N Jill and their C6N1 Myrt. Both look like beautiful kits – I may have to find shelf space somewhere for them…
Have you visited j-aircraft.com? Great site for info on japanes a/c. Check out this article for starters:
PH Zero and Kaga Kate Colors
Here is another interesting thread related specifically to Hasegawa paint instructions for a ‘silver’ underside:
New Hase Kate: Silver unders?
Tell me about it, I used to have an obsession with RL. 76 and if it was a very light blue grey or just light blue. I ended up using RLM 65 for every Luftwaffe aircraft, just because the vibrancy of the colour maked the aircraft look good.
First baby steps on my Kate, engine has been built. Now? Onto the cockpit.
Before WW II, it was common practice to paint aircraft silver overall as a corrosion prevention measure, so the Kate may have been finished thusly, with the green added to the upper surfaces as camouflage as others have suggested.
Japanese aircraft colors are an ongoing debate, with new information surfacing all the time. Back in the 1970s, we all painted our Japanese WW II aircraft interiors with Aotake, using basically a mixture of silver and blue. But Aotake was actually a clear with an added tint of blue or green, to help the guy applying the paint to see it being laid down.
And then we learned that most Japanese cockpits were actually a green, although some exceptions like the Ki-61 Hien were more like a mustard yellow/brown. I think I have also read somewhere that a bluish-grey was used in some aircraft. And was it the NASM Irving that had Aotake used on the stringers inside the crew areas? So confusing! :flushed:
Guess I’ll just stick to the instructions and paint everything as generic as possible :rofl:. Japanese colours are really another can of worms, the first one is the Luftwaffe RLM shades!
New update! Cockpit has been finishes, quite a fiddly step with many small parts. Everything was painted “Interior Green,” IE whatever light green I had around!
Cockpit trapped inside the fuselage halves. I’ll start work on the wings while the fuselage dries.
The B5N was a big plane when compared to others. Just wait till the wings go on and you’ll see what I mean. She is looking really good so far, Sturmovik!
This is the one that I built for a Battle of Midway group build…
