Hasegawa Clerget 9B
I’m down to the finishing touches on Hasegawa’s Clerget 9B in 1/8 scale. The one thing the kit really needs is a prop, why they didnt include one is beyond as it would really bring the finished kit together. I cant seem to find anything, so i figured it was time to bring my quandry to the masses. Does anyone know where I could find a 1/8 scale prop?
I recall having seen aftermarket suppliers of laminated and hand- carved real wood props for a variety of scales. Also resin ones…probably check someplace like Shapeways.
A short Google search should turn up these and other possibilities. Would also be a good idea to check the various WW1 modeling forums, since the question is likely to have come up before.
Cheers
Hi;
Do you have easy access to a local small airport? If so you might find one in their gift shop!
You could check suppliers for R/C planes as they have scale equipment for up to 1/4 scale. Been out of that part of the hobby for a long time so I don’t recall many names but Tower Hobbies comes to what’s left of my mind.
Hope that this helps.
Jim [cptn]
Stay Safe.
I used a wood rc prop on the two 1/8 williams bros engine kits I have built. I merely sanded off the brand markings on the WW1 kit and refinished it. The pw Wap jr was a bigger job since it required a variable pitch metal prop I cut it in half and rounded the inner ends to fit into the hubs. TThen I put a super glossy black undercoat and Alclad.
