This is an old 70s kit that I had in the stash for years and finally decided to finish. It’s re-scribed, and I added some simple cockpit detail, 3D-printed new exhausts and drop tank, and printed new decals. There’s a much newer ICM kit but to me the undercarriage looks wrong.
Looks great mate!
I saw a build of an Airfix Ki-46 “Dinah” that hasn’t been retooled since the first mould was made in 1965, and was re-released as a “Vintage Classic” this year. That builder rescribed the panel lines too (although admitted he went a bit hard with it). Is the view that the older toolings just aren’t crisp enough to render the panel line detail accurately, or are we as modelers just looking for deeper recesses so that they pop a little more under preshade/wash?
Nice build, excellent work!
Thanks @prt54. For me re-scribing is the one stage that elevates an old kit to a more ‘new tool’ standard, and yes, I do personally like the look of washed panel lines.
That’s a great looking model! Well done.
Wow, that is an immaculate build! Everything looks so clean and precise, especially considering it’s 1/72 scale. That’s a tiny airplane, and the finish is just beautiful.
I’m particularly impressed with how crisp all those orange markings look. Are those part of the decals you printed, or did you mask and paint them? If you painted them, I’d really like to know how you managed the masking at that scale.
Beautiful work!
Thanks for the kind comments guys!
Thanks Sam, the yellow-orange was just masked with Tamiya tape, cut into thinner strips where necessary. The only exception was the curve on the nose, which was cut freehand from ParaFilm.
That’s some impressive masking work, especially considering you did most of it with ordinary Tamiya tape!
But now you’ve got me curious about the Parafilm. I’d never heard of it before, so I looked it up. Interesting stuff! How did you go about using it on the nose? Did you stretch it over the surface and then cut the pattern in place, or cut the mask first and then apply it?
I’ve been fighting with some curved theater stripes on my F-86, so I’m always interested in learning another masking technique. I think I may have to add some Parafilm to my collection!
One more question about the Parafilm. I’ve been looking around for some, and apparently there are two different versions available: the laboratory Parafilm M and a narrower grafting tape used for plants. Which one are you using? I’m tempted to order some and experiment with it, but I’d rather get the right stuff!
I use the ParaFilm M type. Basically you peel it off its backing paper, stretch a piece of it, and then press it on to the model’s surface. Then with a new #11 blade, cut out the shape you’re masking. I like the stuff because it’s translucent and you can see what you’re cutting, and it has no adhesive so it leaves no residue, but it creates a perfect seal along the masked edge. It’s great for canopy masks too.
