Folks,
Yesterday (6 March 2004), I got my hands on the new Hasegawa Harrier. As with most Hasegawa kits, it’s molded in light gray. Some of the parts had a little flash, which surprised me, being a new release. But all parts were well-molded. And, of course, the windscreen and canopy have ridges right down the middle. The instruction sheet is typical Hasegawa - one sheet with all build instructions on one side, and the paint instructions on the other. The decals are for two Cherry Point, NC, squadrons - VMA-231 Ace of Spades, and VMA-223 Bulldogs. There are missiles, gun & ammo pods, targeting pods, and fuel tanks, but no bombs. The exhaust nozzles are connected internally by two shafts - one for the cold (front) nozzles, and one for the hot (rear) nozzles. This will allow them to be rotated together, except that only two at a time will move - either the front or the rear, but not all four. The nose cone and cockpit are separate sections, as is the tail cone - maybe there will be a TAV-8B coming in the future?
I always start a kit by gluing together the parts that don’t need paint - wings, vertical stabilizer, fuel tanks, etc. But, in this case, the instructions state that the lower portions of the wings should be glued in place before the upper portion is glued to them. So, I think that I’ll follow the instruction’s suggestions. This kit is the first I’ve built that you can glue the fuselage halves together before anything else is done, as the cockpit is a separate section. This makes the build go very quickly initially. So far, I’ve got the fuselage, LERX, gun & ammo pods, nose cone, all four nozzles, intake lips, and wheels glued together as separate sub-assemblies. The LERX (Leading Edge Root Extension) needs quite a bit of filler on the bottom where the top and bottom halves meet. Nothing major, though. ALso, the gun & ammo pods need a little filler on their bottoms along the seams.The fuselage went together very well. They way the kit is designed, you can still get to anything in the fuselage after it is glued together. For some reason, Hasegawa wants you to paint the entire interior of the fuselage gray, but you’re not gonna see anything in it once everything is in place… The wing mounts to the top of the fuselage (just like the real thing), and the cockpit mounts to the front of the engine intake, which is glued in place after the fuselage is glued together. Hasegawa has a well-engineered kit here. So far, it goes together very easily.
This is as far as I have gotten so far. I really like the design of this kit. It makes the build go so much quicker and easier. More later…
