Hasegawa 1/48 Ki61-I Tony done
This is my first time trying to do two builds at the same time(except for two of the same kit)
I’ll be adding Eduard PE and a Squadron vac-form canopy, and just a touch of scratchwork in the pit.
003.jpg picture by fermisb
Just like the P-40 I have going, I started by assembling the wings and setting them aside to move on to the pit.
The kit supplied seatpan is pretty clunky, so I carved/sanded a blank on a piece of wood and crushformed a new one. Got it right on the second go.
The Eduard set does a great job dressing up the pit.
Great looking office! I built this kit last year…from what I can remember I had no trouble at all with the build. Here`s a pic of mine…OOB build.!(http://i278.photobucket.com/albums/kk103/animechick18/Kawasaki Ki-61/DSC01135.jpg)!(http://i278.photobucket.com/albums/kk103/animechick18/Kawasaki Ki-61/DSC01132.jpg)
Holy crap…
Don’t you ever sleep man? Seriously good stuff, I love watching your WIP threads! [:P]
One of my favorite Japanese A/C’s. I have this kit and will watch with interest.
Love the office!
GReat lookin’ cockpit…
Love the Tony m’self, mostly because it’s an unusual aircraft, as Japanese birds go… Here’s my Arii copy…
Curious as to how the Hasegawa compares, both in detal and price…
Nice all around. I haven’t done the 1/48 but hear it’s real nice. If it is 1/2 as good as the 1/32 your gonna love it.
This one is in about the same condition as my P-40, about ready for paint. However, I don’t think these vac-form canopies are meant for this kit. They are molded as one piece, just like the kit canopy. The kit canopy is nice and crisp and clear. The vacs are a touch cloudy and don’t even fit. They are not an improvement, at all! Here is the fit of the rear section. Way short. I took my time and cut it as “tall” as possible.
035.jpg picture by fermisb
The forward piece doesn’t fit any better. So, it looks like I’ll have to cut the center section from the kit part and use the front and rear sections, and use the center section of the vac-form, to pose the canopy open.[bnghead]
I guess those Squadron canopies aren’t always an improvement then…would be a shame not to have the canopy open though to show that pit detail…[Y]
Excellent work on the pit. Keep us posted.
Reards, Rick
I added a couple bits of acetate for the gunsight glass.
002-1.jpg picture by fermisb
I knew a few people have mentioned having a hard time with cutting masks for the clear parts. A little trick I’ve used for years (on canopies that don’t have very pronounced frames) is to hold the backside toward a light. You’ll be able to see the line were the cut should be.
Having troubles with the vac-form canopy (poor fit), I cut out the center section from the kit canopy (molded as one piece. BOOOOOO) and used the forward and rear pieces, and used the center section from the vac-form canopy (also molded as one piece)
Much better fit!!!
Vedy vedy nice!! I too was dissapointed in the Squadron vac formed canopies for the 129 im working on right now. Looks like you’ve got everything under control!!
Nicely done…looks like you have another “Reader Tip” to submit…
[Y] submitted!
Heh… Squadron makes two sets… One for Hasesgawa, one for Arii/Otaki… SQ9561 is the Hasegawa canopy, SQ9531 for the Arii/Otaki kit… Found that out after the fact…
Had to do some surgery on mine since the forward fuselage section needed to cut off my canopy as I’d already closed up and finished the aircraft. The Squadron canopy would’ve had me cut the aft fuselage about a half-inch to accept the winscreen fairing… Ended up with a windscreen that didn’t fair into the fuselage right, but I did some shim work to raise it and get it done… Doesn’t line up closed since I had to “pinch” it a bit, but looks fine open…
You pulled your Tony off quite nicely Fermis, old boy… Wish I’d thought of that little light trick too… But, I freehand anyway, lol…
Nice save and great idea.
Not much to update on, but the top colors are on. The belly will be in NMF.
I used different shades of MM enamel, Green Drab, to break up the monotone and show slight weatering.
005-3.jpg picture by fermisb
Nice shade selection…will be interesting how you dress up the monotone scheme w/ markings to make it more interesting…[Y]
She’ll have some color!!!
Japanese aircraft bore me, so she needs to be colorful!!!
Some blue, some white, some red, even some “non-slip” gelb!!![:P]
Fermis,
I looks great so far.[t$t]
I don’t know how l missed this one.[:^)]
My research tells me these things had licensed-built Daimler Benz 109 engines in them…cool…
