Hasegawa 1/48 F-86f30 Completed
No problem brother. Nice job on the gloss black. What shade of Alclad are you going to use for the overall aircraft?
Here’s one I did in #106 (white aluminum) with different shades on different panels (#116 - semi matte aluminum, #103 - dark aluminum and #112 - steel). Bit of a pain to mask certain panels but it makes for a really nice contrast.
Not trying to hijack your thread but the extra bit of effort to mask and paint those tonal differnces really add to the realism factor. Looking forward to more photos and the completed project.
No hijack mate :slight_smile:
I usually use only airframe alluminium with the same tecnique of spraying a few coats to get a dark allu, then mask and spray more to get a lighter allu.
I don’t use different alclads, it is to expensive here and the results I get I am OK with.
The only thing I need to keep inmind is the upper wing centra spanwize pannel that is more dull.
Theuns
Here it is in 3 coats of airframe allu. I usually at this stage mask off the panels I want to look a little darker and shoot more alclad to make the rest lighter…I now have 2 ways to go with this model
  1. the decals are for a nice 1960’s plane in the normal “used” NMF
  2. I have a pic of the same plane as a super pollished airshow plane, where basically only the gun panel and exhaust looks a little darker, the rest of the metal looks uniform due to the pollishing.
What to do what to do…
Theuns
I see now that the airshow one has what seems to be grey on the centre pannels and wingtips…not sure I want to do this :frowning:
Theuns
Now thats what I call shiny.
Not by any means an expert on NMFs, but I did notice the front areas tend to be a lot more polished and shinier than the rear areas of the plane?
I masked off the outer sides of the wing centre section and put 2 more coats of airframe allu on to lighten that area.
I also masked off the fuselage panel that in all the pix I have seems to be darker aswell as the exhaust and gun pannels.
I will shoot more alclad to laghten the rest , then I usually put 1 coat over everything (unmasked) to make the tone difference a little “softer”
Theuns
This is looking so, so good, Theuns!
-BD-
Hey Theuns, nice work on the cockpit and that NM looks flawless!!!
Just wondering, are you using the box decals are aftermarket- a South African bird maybe?
That simply looks great. Fantastic NMF.
BK
Thanx
I am not sure about the final scheme yet, I used Hasegawa decals on my 104 last year and they were great, I will have to have decals made up if I went Kofrea SAAF.
The SAAF only had 1 hardwing Sabre in theatre # “Q” 622. (USAF #52-4572)
For those interested here is a link to a SAAF forum I am part of showing nice pix of SAAF Korea Sabres.
http://www.saairforce.co.za/forum/viewtopic.php?f=2&t=7069
http://s991.photobucket.com/user/Jolley-Roger/media/Q-622_zps04c983d3.jpg.html
Theuns
Thanks Theuns, those are some great photos there- I really like ‘Naughty Nelly’.
Gorgeous NMF…
I started with the decals last night and sofar I am not really having allot of fun with them :frowning:
I wanted to do the Korea decals, the large central fuselage band (after breaking up) convinced me to do the other supplied decal scheme!
Then the nose decal on that scheme broke up…I got it somewhat inplace but not really 100%, so I will just beat this thing into submition anf complete it.
Theuns
Theuns - I have extra decals for a postwar bird if you want them. They’re Aeromaster or Scalemaster. Anyway, let me know.
-BD-
Brandon that is most kind of you thanx allot :slight_smile:
I started putting microsol on these difficult decals and I think I will get them to go down a little better, just a pitty they cracked but I have to get the thing dome otherwize it will just sit in the box.
Atleast the ones that I think may give me hassles are on the bird so hopefully the worst is behind me.
T
Sure thing. Let me know if you change your mind. They came with my kit and I don’t see using them, so they’re spares. I also have a spare kit sheet, but they are wrinkled on the sheet. The one decal I used came off just fine, but I wouldn’t trust them.
-BD-
After a 3 hour decals marathin I got them all on last night, I will microsol all and see where I need to touch up before clearcoat.
Theuns
Nice NMF Theuns! The office looks awesome too!
I managed to beat the decals into submition and shoot a satin clearcoat over it so it looks like a well used plane but not loose the alclad effect.
In the bright sunlight in the pix it looks a little darker than it really is.
Theuns
Wow! Very nice work, Theuns. Almost done. Can’t wait to see the end result.
